Aftermarket tach connection location?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90Sub, Mar 22, 2002.
  1. 90Sub
    90Sub Newbie
    Feb 21, 2002
    Newport Beach, CA
    I have an aftermarket tach mounted on top of the dash, was installed before I bought the rig. I was wondering where those type actually hook up so I can check the connection. It's starting to go out sometimes. Anyone know?
  2. MudTruk
    MudTruk Registered Member
    Jul 21, 2001
    32
    Norman, Oklahoma
    well, typically there are 4 wires to hook up a tach. I am assuming that you have a "standard" tach. The colors may (can) vary by manufacture. Black is 12V ground. It is always good to check your ground wire. Many problems can be solved by a good ground connection. Usually the red wire goes to the distributor on the Tach electrical lead. This is usually a soderless spade type connection on GM HEI coils. My tach has a constant power lead that is connected to a 12V switched source. And the last wire connects to an instrument panel switched hot lead. This is to provide lighting to the tach when the lights are on. Hope this helps.
    Pete
  3. A&P
    A&P Registered Member
    Dec 3, 2001
    88
    San Antonio, Texas
    I have a sun pro 4 1/2 incher. Goes like this
    Black=Ground
    Red=12V Source IGN
    Green=Dist. Tach Lead
    White=Dimmer
    Just My $.02
  4. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    My AutoMeter is hooked up the same as your SunPro.
  5. Anteak
    Anteak 1/2 ton status
    Nov 7, 2001
    105
    Hemet, Ca.
    What about a S/W 0 - 8,000 tach????
    There are only three wires;
    Black
    White
    Red
    The green wire doesn't exist.
    73 Blazer, So. Ca.
