Aftermarket Tach installation
Discussion in 'The Garage' started by Muddytazz, Jun 22, 2003.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I've got an aftermarket tach and can't for the life of me figure out a good place to mount it. I've got a TH350 so i can't mount it on the steering column, and i just found a mint condition OE dash pad at a yard so i don't want to put any holes in the dash pad to screw it down. What are some of the placed you've mounted yours /forums/images/graemlins/ears.gif
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    if it's not very big you could mount it on the steering column. i put mine there. i positioned it so that when i'm in drive it's just below my speedometer. i can get a pic later if you would like.
    rick
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    could you? I think mine is about 3" to 3 1/2" in diameter or close to that.
  4. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Imounted mine to the column and couldn't figure out why I couldn't shift outta P for the longest time... /forums/images/graemlins/tongue.gifYou could mount it to the A pillar.... /forums/images/graemlins/thumb.gif
  5. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    here you go. the first one is the tach with the tranny in drive. and the second one is park. my tach is about 2 1/2" in diameter. hope these help you out. from where i sit, it doesn't block the view of anything.
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Looks good, what did you do about the wiring and routing them?
  7. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i ran the wires through the rubber ring where the column meets the dash. as for the firewall, i ran the wire going to the coil through an existing grommet. the light i just plugged in with my dash light fuse. i just grounded it to the metal part of the dash. if you have any other ?'s just let me know. i'll help you the best i can.
    rick
  8. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Check out BranndonC's thread here
  9. Geno
    Geno Registered Member
    Nov 18, 2002
    52
    Dorchester, Nebraska.
    I put mine under the dash right below the ash tray angle towards me, its easy to see and not in the way. /forums/images/graemlins/cool.gif
  10. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    how about here?
