Aftermarket Tailgates (non OEM)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JoeAngelicchio, Jul 3, 2002.
  1. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    For anyone who has installed a non-OEM tailgate (made in Taiwan), how were the tolerances? Not bad or bad? Did you have to work it alot to fit properly? Tailgates in my area (Canada) are $592 cdn for a GM and $292 for an aftermarket one from NAPA.
    Thanks.
  2. JoeAngelicchio
    Feb 18, 2000
    628
    TTT. Anybody???? /forums/images/icons/shocked.gif
  3. Rix_Gotta_Blazer
    Rix_Gotta_Blazer 1/2 ton status
    Dec 13, 2001
    104
    Hollister, CA
    my dad bought an aftermarket tailgate from J.C. Whitney. It was for his '79 1/2 ton PICKUP though. It was a pile of garbage. I think that it was made of beer can material. j/k. but honestly, the first time that we put over 150 lbs. on the center of it, it folded right down the middle. It wouldnt even close right after that. In my opinion, OEM parts are the best... if you are able to come by them. I know that i will never buy a tailgate from J.C. Whitney. But that was just my experience.
  4. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I have one on my 79 K5 and it did not fit worth a crap at first
    I had to do some cutting on the bedsides and bending on the
    tailgate to get it to close. the metal is ok not as thick OEM, but for $190 what should be expected.....
  5. 76chevy
    76chevy 1/2 ton status
    Aug 16, 2000
    246
    Utah
    I bought a tailgate for my 76 truck. They were something like $450 for a GM and I got one for somewhere around $99 at an autobody supply store. The metal is from Tiwan or something so it isn't as good but it works ok.
    Since I had a 76 it was different than all the availble tailgates (77and up). I had to go to a junk yard and get some hinges from a newer truck. They bolt right on no problem.
  6. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    Mine is aftermarket. Most of it fit OK. The only thing I had to do was drill a bigger hole in the window regulator cause they didn't match up. It worked fine otherwise. The best thing about it was no rust!
