AGR or 2WD box?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChadH82, Jun 16, 2001.
  1. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    I'm going to do a crossover steering conversion on my D60 and I was wondering what box I should use? How do they compare in price(new)? Is an AGR that much better? If I go with the AGR should I get the AGR pump also? Thanx
    Chad
  2. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    I bought AGR's box and pump and wish I didn't. I could of used the money on something else.
  3. ChadH82
    May 9, 2001
    400
    So you would reccomend the 2wd box? What don't you like about the AGR box? Does it steer easier than the 4wd box?
    Chad
  4. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I, like Titanic, also bought the AGR box and wish I didn't!!!
    WASTE of MONEY!! They just blow all together. I guess the problem with it is the cost...and the fact that mine runs super hot no matter what. Yesterday when I was ramping my truck, I notice that I was loosing good steering feel, (like my power steering was going), and then I got out and touched the gear box and almost fried my hand off!!! Junk was hot!!
    Anyhow a regular 2WD gear box (new) is like $170 or so. AGR's is like $350!! You do the math.
    Boss
    ps, their service stinks too.
    <A target="_blank" HREF=http://www.boss.coloradok5.com>http://www.boss.coloradok5.com</A>
  5. ChadH82
    May 9, 2001
    400
    Ok. Thanx guys. I'm going to the salvage yard today to see if I can find a good one. If not I guess I'll shell out $170 for it.
    Chad
  6. titanic
    Mar 27, 2000
    498
    The crossover steering design will help some which requires a 2wd box but all you need is a stock one and perhaps a new stock pump.
  7. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    I got a rebuilt lifetime warranty 2wd gearbox and pump from Autozone. I've replaced each of them once already and need to replace the pump again. It cost me very little to replace and the service is great at Autozone. I'm going to put a cooler on the low pressure side of my pump. The heat torches the pump until it leaks and gets blow by. The gear box broke inside because the driver uses too much loud pedal. [​IMG]
    CB
    1973 K5, 400TPI,TH350, 203/205, Dana60/Detroit/5.38 front and rear, 38" TSL's on steel wheels
    <A target="_blank" HREF=http://www.azk5.coloradok5.com>http://www.azk5.coloradok5.com</A>
