AGR pump on hydro ram setup
Discussion in 'The Garage' started by 89Burben, Apr 18, 2007.
  1. 89Burben
    89Burben Registered Member
    Jan 3, 2005
    98
    CT
    about 4 months ago the power steering pump on my truck crapped out. I figured to try the agr "super pump" from summit.
    Question is that will this pump work with the hydro ram setup i am installing? Will it have enough pressure and volume? Anyone ever try it?
    I kno most people do what west texas offroad does to the stock pump by drilling some holes and stretching a spring to 2 inches. (ive read the article)
    But i figured id see if this AGR pump is any good, rather than screwing around with an older pump i have.
    Here is the descrption on the pump:
    if noone knows then i guess i will take the agr pump apart to see if the holes are larger than stock to improve volume, and see what the spring is like....
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Run as fast as you can from AGR. They are total trash now. Back in the day the where a good product. Look into PSC motorsports for there steering components. As for if it is any better than a stock pump I have no experience.
  3. 89Burben
    Jan 3, 2005
    98
    CT
    yeah i kno........but i already have the pump.
    i called them and it is the same pump they run on their rock ram kit so it should be good enough
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Oh ok, thought you didn't get the pump yet. Well good luck with it.
