Agr Steering Box - Read!!
Discussion in 'The Garage' started by Eric M., May 23, 2006.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I have a 2 month old AGR steering box. The 4 bolts on the top cover loosened up and did so quick in about a day. I lost all my fluid in one shot, no power steering and no brakes (I have hydroboost). I tightened all 4 bolts up and everything seemed good. I decided to give AGR a call since it really seemed odd that the bolts would loosen up like that ... and i didn't want to experiece this again!
    It turned out AGR got a batch of bolts with the incorrect pitch in the threads which caused them to loosen like that. About 50 boxes went out before they noticed it. They are sending me new bolts.
    Just a heads up. If you have a fairly new AGR box and your cover bolts loosen, give them a call and they'll send you new ones.
    Eric M.
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    If these bolts had the wrong thread pitch, then how did they get them to screw into the box in the first place (force them in)? Anybody that has a little experiance screwing a bolt in, can usually tell if a bolt is the wrong pitch imidietly just by the feel of how the bolt srews in. I have heard some not so good things about AGR in the past.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    It could very well be that arg's su[[lier made a mistake while manufacturing the bolts. if the tooling isnt setup right they may be slightly off allowing for such a thing to happen... it wasnt noticable cause it was close but it could still cause problems.
  4. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    If any of you guys are "bolt experts", I'll send the bad ones off to you to measure / check out.
    Eric M.
  5. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    When thread pitch is incorrect, at some piont (probably no more than 1/2" depth) the bolt will bind. One machining problem I have seen with bolts is the thread pitch is correct, but when the bolt threads where machined, it cut too deep, and the bolt was cut just slightly undersized...causing it to not sit flush when threaded in. I had that problem with a tie rod end one time.
  6. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    M8 and 5/16" are so close both will thread into the wrong hole to their full depth...even though the thread pitch is slightly different.
    I'd guess that may be the size and the problem.
    Rene
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    That could very well have been th problem but the said th pitch was wrong to clarify the problem rather than having to go into detail.
  8. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Exactly! ;)
  9. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    dont get me started on thread pitch and machining threads, it will be a long night :D .
  10. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    [/cracks beer]
    [/sits in comfy chair]
    Why? Do you happen to know something about machining? :D :bow:
    :usaflag:
  11. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    AGR - I am surprised they are still in business.
  12. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    If the pitch was bad on the bolts I wonder if they messed up the threads in holes when they installed them , you might have proplems later!!
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    and when you do have problems, they have record of sending you bolts... so they knew there was a problem. you should be covered.
  14. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Man ... I don't want problems and I don't want to have to deal with pointing fingers and trying to get money for a bad box or a wrecked truck in the future.
    I need another box for a different truck. Who can you guys recommend?
    Thanbks,
    Eric M.
  15. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Junkyard! Or just buy a rebuilt one from parts store.
  16. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Come on!! You can do better than that!
  17. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
  18. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Now we're talkin'!
    Anyone use one of these? Feedback? I don't see any sort of write up like AGR does on their boxes, you know, boasting about special berings, heavy duty parts and bolts with correctly pitched threads. Are these boxes beefed up at all or just stock rebuilds?
    Thanks,
    Eric M.
  19. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
  20. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
