AGR Steering Boxes and Pumps
Discussion in 'The Garage' started by guido666, Nov 10, 2005.
  1. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    I used to have a '76 Blazer, and bought a AGR pump and box for it. The '76 is gone but now I have a '79. Online the boxes are for '68-'76 and '77-'79. What were the differences? Can I still use it? If not it will be for sale soon (or if it is going to be a pain to get whatever I need to adapt the two).
    Also, this is from the listing:
    "S Box - S Series Designed for the Off-road enthusiast who wants to reduce their steering effort. These steering boxes are manufactured with light valving and 20:1 ratio to obtain maximum power assist with less effort from the driver.
    NOTE: This steering gear is not recommended for short wheel base vehicles at highway speeds. This box turns very easily and over correction can occur in emergency maneuvers."
    This may sounds stupid, but they don't consider a Blazer a short wheelbase vehicle do they? I wasn't sure if they were talking about a Jeep in relation to a real truck (Blazer/Pickup) or if they are talking about a Blazer in relation to a Pickup.
  2. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    blazer is cosidered short wheelbase.
    i might be wrong but i think the difference between the two boxes is the fitting. they switched from stanard to metric. thought that was in the 80's tho.
  3. guido666
    Feb 16, 2005
    788
    Longmont, CO
    On AGR's site it says "Short wheel-base Jeep CJ's, TJ's and similar sized vehicles should consider the SB2 box if driven at highway speeds." Anyone know the wheelbases of a CJ, a Blazer (106"?) and Pickup off the top of their heads?
    Does anyone have a K5 with a SuperBox1 in it that uses it as a DailyDriver?
  4. guido666
    Feb 16, 2005
    788
    Longmont, CO
    So if I have the whole setup from the '76 (new AGR box, new AGR pump, and '76's lines) I should be good to go?
  5. guido666
    Feb 16, 2005
    788
    Longmont, CO
    ToTheTop.
    Anyone want to chime in?
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    yes, you should be fine
