AGR steering boxes, are they really better?
Discussion in 'The Garage' started by zakk, Apr 13, 2002.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I am gaterhing parts for my Mid-May Wrench-a-thon, and need a 2WD box for the x-over conversion. Obviously the junk yard cores are a dime a dozen, but the AGR's run about $400.
    Is that cost justified? Are they really *that* much better? I don't plan to use the rock ram, either.
    Suggestions, comments, rants apprecaited!
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    In 1 word, NO. 99% of they people that have them had nothing but problems with them, not to mention their customer service.
  3. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    I would go with Lee's Manufacturing steering box. They do a ton of the Score and Corr truck steering boxes and they are pretty reasonable. The cost I think was around $210 and to up grade to a different torsion bar and valves it cost $65. I will get you the phone# Monday
  4. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
  5. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    if i remember correctly. west texas offroad is offering members a discount here, also the shop foreman shows up posting in the forums sometimes
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Well, now that ORD is repping them I feel the support will be there...............figures I'd say that, I just bought a barely used AGR box for $75 for my crossover............/forums/images/icons/smile.gif
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    oh, just *RUB* it in!/forums/images/icons/laugh.gif
  8. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Zakk,
    The only thing that's got me thinking AGR for my own rig (eventually) is the availability of the variable ratio box they've got.....it gives you a milder ratio for "on street" driving but as the wheel starts to turn more to the extreme ends, the ratio gets a lot "quicker".
    I guess that if you buy a "fixed ratio" box that's qucker than stock....it tends to feel "darty" on the highway....small movements of the wheel tend to make the truck really shift around in it's lane......I think that would get OLD in a hurry!!
    All this being said, I don't know if there are other options out there for "variable ratio" boxes that would do what I'll need. It's one of those areas that I haven't fully researched because it's TOO far down on my project list!!! Just wanted to give you some additional things to consider in case they are important to your decision making also.
    HOOTUS.
    -Greg
  9. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    NO!!! AGR boxes are just over the counter boxes. There is nothing different about the boxes that they sell.
    The only thing you MIGHT get is a stiffer or weaker assist valve body. But this does not have any effect on over all power, only on the way it feels to you.
    If you want a variable ratio box from the pick and pull then take a 9/16 wrench and a small hammer with you. Remove the 4 bolts on top of the box and then tap up on the pitmanshaft about 1/4" and then rotate the top housing 180 degrees so that you can see the 3 teeth inside on the shaft. if the teeth are all the same length then it is a not variable ratio and if it has 1 longer tooth in the middle with a shorter one on each side then it is variable ratio.
    For an easier reference, most 3 1/4 turn boxes are variable ratio and most 4 1/4 turn boxes are not. but this is not always true.
  10. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
    hey, lakerat, you guys offer us ck5 members a deal, don't you, even more if we are from texas, right?
  11. TheLakeRat
    Nov 29, 2001
    363
    Yeah CK5 members do get a discount. and if you come down to the mud bogs this weekend since your already in Texas i'll give you an even better deal.
