AHH! No power steering! Help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zcarczar, Oct 5, 2002.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    My power steering started going crazy the other day when i was off roading, it wasnt giving any assistance at slow engine speed, like in a parking lot, So i put some fluid in it cause it was low and it didnt do a thing. Then i tried to bleed the system and it started puking fluid out of the resivour cap. I went and got a new cap and tried once again to bleed the system and it keeps puking, and the steering is no better. Did i burn up the pump or what? I need some help please!
    Jason
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    sounds like the pump /forums/images/graemlins/frown.gif
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have the same problem only it comes and goes, I hope that I can fix it before it dies.
    How do you bleed it?
    Mine was a little low and I topped it off and it was a little better, then it started to act up again. The fluid level is still good.
    Is it still salvagable?
    I was thinking I would rebuild it, I know that fluid gets hot and becomes gummy anyone with experience on that?
    IceMan
  4. zcarczar
    Feb 10, 2002
    2,495
    I was told that a proper way to bleed a power steering system is to turn the wheels from lock to lock 20 or 30 times with the engine off. Thats what I did when i replaced my steering gear.
  5. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Be like a nickel whore and get some bigger forearms. haha.
    One of my friends learned why you don't put a 14" steering wheel on a fullsize truck. If you lose power steering and have 40" rubber you might as well get out a come-along to turn the tires or have the arms of He-man.
    I'd plan on putting a new pump in. They don't like big tires, low fluid, or excessive heat.
  6. Great78burb
    Great78burb Registered Member
    Sep 24, 2002
    28
    San Diego, CA
    /forums/images/graemlins/eek.gif
    My pump throws a fit about turning my tires with the engine running! I guess maybe if I jack up the front of the truck? /forums/images/graemlins/burb.gif
