ahhh my back
Discussion in 'The Lounge' started by 84gmcjimmy, Dec 20, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I've been wrenchin on the blazer chassis all day, and all the bolts that hold the springs at the rear on (3 per side, total of six) were seized so much my impact wouldn't budge them. Either there is something wrong with the impact, or they were actually on there tight. I had to pull out a cheater bar, but even that was tough. So I just got the 3 off of the drivers side, and haven't tried yet because it was getting way to dark out, and I was tired and sore. Anyways, my back hurts because the only thing I could use to unwind them was all my bodyweight/momentum to get them undone. It wasn't the first 2 turns that was hard, the WHOLE thing was hard.
    Hopefully my back doesn't hurt worse tomorrow. I am almost done!
    See post in garage for what I did today............
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Sounds like you might need the ol'blue tip wrench.
  3. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    PB Blaster :thumb: Give it a shot, let it sit...shoot it again....wait. THEN try it.
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I don't have PB blaster, but I used something simular to it, called MOOVIT and it didn't help much, maybe not at all...
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Your talking about an oxy/acetylene "wrench" right? Don't have one, yet:xmas:
  6. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    as Z3PR said " time for the ole hot wrench"!:weld:
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Thats the problem... There isnt anything else like PB Blaster that I have found.
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    next time I am downtown I will look for PB blaster. What does the can look like? I've never seen it there before, but I might not have been looking hard enough...
  9. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    I don't even try to remove those bolts the conventional way...life is way to short for that crap!
    I use a thin cut-off disc on my 7" grinder between the hanger and the side of the spring. Then, if I'm saving the springs I'll either drill the rubber out around the sleeve, or burn the bushing out, then remove the remains.
    At the very least make sure you grease the hell out of the new bolts when it goes together. Better yet is to run ORD's greasable bolts and bushings...
    Rene
  10. joefl
    joefl 1/2 ton status
    Aug 18, 2004
    153
    Marianna, Florida
    PD Blaster I got is in a white can with all kind of lettering on it. it works good. try auto zone
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Ah, I guess when I put it back together I could get ORD's greasable bolts wih the bushings. Does it come with 12 bolts all together? (3 per spring) .
    I guess I will just cut the rest of the bolts off.
    Thanks Rene
  12. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    GM's "Heat Valve Lubricant & Penetrating Oil" comes really, really close. Might even be the same stuff.
  13. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    here ya go steve
    :xmas: [​IMG]good stuff worked real well for me, but than again my rig diddent have any rust, but it made everything a little eaiser to got off considering i was only useing hand tools:xmas:
  14. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Thanks Surpip, LOL that can won't be to hard to spot!
    If i can't find the PB Blaster, I will look fr that stuff. Thnks!!
