AHHHHH!!!! HELP!! MY BLAZER DIED!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Nov 4, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I turned out of my driveway and was going up the road and I noticed that it went up to 2500 RPM until it shifted into 2nd, and it jolted the whole truck when it did. I thought that was wierd but continued on. When I started off from the first stop sign the engine would only go to 1400 RPM and would not shift into 2nd at all. I also noticed that black smoke started coming out of the tailpipes, not a lot but it was continous and that it was running a little rough. I made a block around and it continued to only get to 1400 RPM and wouldn't shift. Even with the pedal to the floor it wouldn't get over 1400 or go into 2nd. I got in front of my house when it died. I popped the hood and saw smoke coming out of the air cleaner assembly, it was just a little cause it stopped after 10 or so seconds(backfire??). And now it wont start. What the hell is the problem? Is it the tranny? I'm running a 305/700r4.
    Thanks for any help.
    [​IMG]FUN WITH 31's![​IMG]
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The same thing happened to my friend today. He blew the engine going 75 down the highway. The people at the gas station we took it to were cool and they said they could tell it was blown because the dipstick was blown out of the tube about an inch or two.
    90K5
  3. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    back to the top
  4. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    actually it may be the seals in your carb my buddy's truck did the same thing dumping tons of fuel check the plugs to see if their flooded. he found a holley new at cragen for 275$
  5. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    Sounds like a carb problem to me as well, do you have a spare carb you can try? It sounds like some debris is fouling up the innards. My Dad used to have a Cornbinder pickup and his did the same thing, it ran worse and worse, with less and less power until it finally quit on the side of the road. He got out and had a look and there was fuel pouring out of the carb. 1 reman carb later and he was back in business.
    Rene
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I have heard of the vacuum modulator going out in the tranny, causing ATF to get sucked up the vacuum line into the intake. Also would cause the tranny not to shift.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    I don't think that 700R4's ever had vacuum modulator lines. Only the TV cable.
    New 4x4 driver: "A lot of money in that truck, eh?"
    Me: "Oh, about 1/4 of a new one"
  8. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Are you getting any fuel to the carb? Could be bad fuel pump.
  9. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    I swapped carbs on Sunday and now it works fine, no problems. Thanks for the advice[​IMG]
  10. Scottsdale
    Scottsdale Registered Member
    Nov 6, 2000
    9
    South Carolina
    Mine is doing the same thing. I adjusted the choke on it and it is doing a little better. Did you have a spare carb or did you buy a reman unit?
    Bowties, hate wearin' em, love driven' em!
