AHHHHHHHHHHHHHHHHHHHHHHHHHHHHH trying to catch up
Discussion in 'The Test Lab' started by jjlaughner, Aug 26, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    post
  2. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
  3. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    man I still have a long way to go, front spring bushings (52" springs), weld in the spacers on the shackles, get the springs mounted, then figure out the knuckle situation, get the flatops done, make a tie rod, figure out a crossover setup, bolt on 2wd box and brace frame, new front crossmember, pitman arm for 2wd box, maybe get new bearings and seals for these 8lug front hubs, bearings and crush sleeve for the 14bolt, get it together and setup the gears, get both of them under the frame, fab up the shock tower and rear axle truss (for axle wrap bars and future add ons), front crossmember and I think I'm going to do a center drop brake line (same as the rear) then tie strap them to the vent tubes, longer vent tubes, replace the broke vent connector on the 10bolt, swap the bumpers over, brace the front bumper, pull the tank and move the rear hangers back a couple inches, swap in the TBI tank, rig up a fuel filter, pull the front clip off the brown blazer, yank the motor tranny tcase, tear the motor down install new seals and check for issues (maybe a cam), rebuild the 700, swap int he new tailshaft, find adapter for 205, clock it and twin stick, line locks for the rear axle, build a stand for the body, roll the old frame out and new frame under, then start narrowing the front end with the new core support, trim the fenders some more, reinstall the engine, tranny, transfer case with new crossmembers and belly pan, new drive shafts, buy bend and install the cage, seats and harnesses... this [censored] thing will never be done... not this year anyways! /forums/images/graemlins/screwy.gif
    post 4
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
  8. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
  10. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/screwy.gif /forums/images/graemlins/screwy.gif /forums/images/graemlins/screwy.gif
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
  12. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/grin.gif
  13. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    took a picture just for you [​IMG]
  14. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    .................... [​IMG]
  15. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  16. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
  17. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
