Aint it beautiful?
Discussion in 'The Lounge' started by mountainexplorer, Nov 25, 2005.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    At least I think so.
  2. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Are you going to strip it down or use it?
    I think an earlier post sayed it had a 454 with 14 bolt rear th400, did it also have an overdrive?
  3. mountainexplorer
    Nov 14, 2001
    4,903
    454, TH400, 14-bolt rear. No overdrive. Came to $723. Wasn't supposed to spend the money on this, but I'm immediately yanking the 16" rims off and the generator to try and sell them real quick to get money back.
    I have some split rims to throw back on to keep it mobile for now. Next year the motor will come out and get a different cam and gaskets and probably go into my Suburban, and I'll sell the 2wd TH400, and the hulk will join the other motorhome and campers/trailers at my place.
  4. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    Hell you could probably cut it down behind the door build a new wall and use it as a hauler/sleeper.
  5. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Didn't you rip your last one apart and go tearing through some mud pits? :)
  6. mountainexplorer
    Nov 14, 2001
    4,903
    I thought about doing that with the last one...
    But we did that instead.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Dude, lift it and convert it to 4WD. I could see it with a 4" or even 6" lift and 35's.
  8. mountainexplorer
    Nov 14, 2001
    4,903
    My "good" motorhome I use and stay in has a solid front end and leaf springs. This one and the other Chevy chassis one are independant fronts, so it would be a major project.
    On my good Chrysler powered one, I could probably bolt in a Dually Dana 60 4.56 front, and add blocks to the rear to make it sit level, and a divorced dodge 205. The rear in it now is a Dana 70 Dually with 4.56s. But if I lift it at all, it won't fit under the shed anymore.
  9. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Had the same problem when my grandfather wanted a bigger boat. We raised the shed ;)
  10. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Liar!
    That's what I thought >:P
  11. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    That thing is dying for the shark style rattle can makeover.
  12. mountainexplorer
    Nov 14, 2001
    4,903
