Air baffle thing ama bobber
Discussion in '1982-Present GM Diesel' started by HIX, Feb 25, 2004.
  1. HIX
    HIX Registered Member
    Feb 26, 2003
    80
    Denver
    I have an 84 diesel blazer on the intake before the aircleaner tharer is this import fart pipe looking thing that I can only assume is an air baffle to reduce noise. It looks quite restrictive with the hard mounted fan blades inside. Can I remove this thing w/o anything blowing up?
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Yep, take that thing off /forums/images/graemlins/hack.gif and throw it away. It's supposed to reduce noise, as you've figured out. But it doesn't really sound any louder without it. Run you a 4" hose from the radiator support to the air cleaner, and you'll be in good shape.
    Casey
