Air cleaner for '91 TBI 350?
Discussion in 'The Garage' started by Garza, Jul 30, 2006.
  1. Garza
    Garza Registered Member
    Apr 5, 2005
    6
    Texas
    I removed the stock air cleaner assembly off my '91 TBI 350. What do you guys use for "aftermaket filters". I really dont want to go with a cheapie chrome one, but it's looking like my only option without spending lots of $$ on one. Also, will I need a spacer or anything or will it just mount right up?
    Thanks,
    RG
  2. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    what ever you do, stay away from a K&N if your offroading, they suck water up real quick
  3. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I just turned the lid of my stock one upside down to get more air :D
  4. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    I just installed one of these. http://ramairbox.com/
    I dicked around with a couple of other attempts short of it was I wanted a simpler cleaner setup. Found it on the net but the place is in my hometown coincidently so it allowed me to check out the stuff first hand which is always nice. Great workmanship, great guy, VERY knowledgeable, a little more costly than I had anticipated though.
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    All filters will suck up water real quick if you dunk them..................
  6. eeyore
    eeyore Registered Member
    Sep 18, 2005
    47
    utah
    i kept the stock assembly with a k&n filter.
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Same here. No problems at all.
  8. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Used an open element for a bit. It sucked in dust at too high of a rate and had to be cleaned/changed often. Went back to a stock setup, and the filter life has increased a whole bunch.
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    they look nice. how much are they? how do you like it? any noticable difference?
  10. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Honestly I'd have to check the cost, but it must have come in close to $240 with tubing and hardware and filter. Like I said the workmanship is great, fit is perfect.
    As for a performance increase, after replacing a ridiculously clogged fuel filter, doing plugs, wires, cap and rotor, and replacing the clogged open air filter that came with the truck, this is the only thing that made a noticeable difference at the pedal.
  11. midnitewarya
    midnitewarya Sounds like a problem for future me. Premium Member
    Dec 1, 2002
    1,726
    20
    SoCal
    For some reason, Ive noticed that TBIs are only happy with the stock configuartion. Everytime Ive seen one opened up, there is always some sort of hesitation. I had a K7N for a little while, didnt like the way it ran. Seems to run much smoother with the FRAM and original ducting. Im sure there is more power the other way, but I prefer it to be smooth.
    Al
  12. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I extended the hold-down stud and used the taller top from a one ton OE filter can. Doubled the height of the filter and kept the cold air plumbing.
    My experience with K&N type filters is that they allow grit past them. Had one on my 'glass buggy and it always had grit stuck to the base of the filter. Tried greasing the gasket surfaces of the filter and It made no difference. Tried plugging the crankcase vent (the only port other than the carb opening) and that made no difference either.
    I give K&N type filters a thumbs down.
  13. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    You woulda been better off with the stock setup.... Not blingy, but way more functional...
