Air Cleaner question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BettyBurb, Feb 3, 2003.
  1. BettyBurb
    BettyBurb Registered Member
    Dec 14, 2002
    52
    NorthEast Colorado
    The tube from the exhaust manifold to the air cleaner extension is missing on my '88 Suburban. What is the purpose of this tube and how critical is it ??? Should I find a replacement and if so where can I get one.
  2. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    if you mean the metal slinky thing think it's called heat stove pipe or heat riser (not sure) but they sell them at napa
  3. jkce457
    jkce457 1/2 ton status
    Nov 22, 2002
    135
    Southbury, CT
    The stove pipe takes warm air coming off the exhaust manifold and pipes it in to the intake in order to help the engine run better while it is cold. I have an open element and have eliminated that system completely.
  4. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I 2nd what jkce457 said.
    /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
    Bo
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    If you have to pass a visual smog test, then it's very critical.
  6. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    good point no slinky thingy no pass in california /forums/images/graemlins/eek.gif
  7. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I see that you haven't filled in your profile. Knowing your location and the year of your truck would really help me answer your question accurately.... /forums/images/graemlins/deal.gif
    That said, the purpose of the stovepipe was described above. A little more info-
    On the neck of your aircleaner housing you'll see a litle round disc. This is a vacuum-actuated door that diverts either warmed air from your exhaust manifold or cool fresh air from outside the engine bay into your combustion chamber. There is a temp. sensor on the inside of your aircleaner that controls the position of the door by sending vacuum to it when needed.
    Basically, when you start your truck, the sensor closes the diverter and warmed air is sent to the carb to help your motor warm up faster. Once a set temperature is reached, the door opens and cool air is sent to the carb. In really warm regions this isn't a big deal, but up in my neck the woods(especially during winter), not having the stovepipe in place will cause hard cold starts and can lead to icing of the carb internals.
