Air Cleaner Spacer to Valve Cover
Discussion in 'The Injection Section' started by btolenti, Sep 6, 2006.
  1. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Hey Gents,
    how does the air cleaner spacer attach to the valve cover? Does it have a special valve at the valve cover grommet? (something like a PCV valve?)
    Thanks!
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    it hooks to a vac line, going to the top of the drivers side valve cover
  3. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    Yeah, I figured that out, but my question is whether or not there is some type of valve in line like the PCV system has...
  4. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    well the valve is the thing that goes into the valve cover, not sure what its called though:confused: :confused:
  5. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    anyone have a pic of the valve, know what it's called, or can tell me where to get one????
  6. eagle mark
    eagle mark 1/2 ton status
    Nov 18, 2004
    3,289
    North Idaho!
    Well on most I have seen the part you have is just the vent. Vent just needs clean air, no valve. The PVC valve hooks to vacuum at the front of the TBI unit.
  7. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    Yeah, I know about the PCV connection. I just find it wierd that there is no valve in the air cleaner to valve cover connection. That would seem to allow the crankcase to ventilate to the atmosphere when the truck was not running.
    I just need to make sure I have all this hooked up correctly so I don't get dinged by the California Smog referee...
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    There is no valve in the vent tube or valve cover connection. on TBI engines. It is just an open tube between the valve cover and the spacer. I doubt if any CC vapors could make it out past the air cleaner/housing/CAI tube when the engine is shut off.
  9. eagle mark
    Nov 18, 2004
    3,289
    North Idaho!
    I should have added that when a PCV valve sucks fumes from crankcase it requires a vent or it will suck in gaskets. This is your filtered air vent.
    Like Thunder said, nothing there. I just looked on my 90 Suburban! :D
  10. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    excellent! Thanks guys. Now I just gotta find where I can get the plastic piece on the valve cover to attach the hose to.
