Air Cleaners
Discussion in 'The Garage' started by CHEVY 4WD, Dec 22, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Ok I drive in mostly in the road but I do go offroad quite alot to. I need a high flowing air filter but being in FL all we have is sand. I though about a 14x6 K&N with a K&N foam pre filter but those K&N are EXPENCIVE and Im kinna running low on money righ now and I really need a new filter and I gotta get a new base too. So whats yalls opions?
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Paper cleaners flow pretty good when new and they are cheap. Also, there are lots of K&N clones out there that cost less.
  3. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    paper, easy to replace, and cheap to replace.
    K&N, washable million mile warentee, you simply wash it when it gets dirty, but are you up to it?
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Napa Gold Air Filter...made by WIX..good filtration, good flow...and cheap...
    Chris
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Here's a cheap trick for ya if you're running low on cash. Just buy some 1/4-20 threaded rod, then stack 2 paper filters on top of each other. Or check out the paper filter that came on some of the GM trucks in the 80's. They're the same diameter as the other ones, but are 5 or 6 inches tall, instead of the standard 2 or3 inches tall. Either will fit in the stock air filter housing, but the lid obviously won't close against the bottom any longer. /forums/images/graemlins/thumb.gif
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Oh yeah, make SURE that the new setup will clear before ya slam the hood the first time. /forums/images/graemlins/shocked.gif If the new setup is too tall you can dent the hood and bust the carb. /forums/images/graemlins/frown.gif But there's usually lots of room under the hood of our rigs. /forums/images/graemlins/thumb.gif
