air, co2, nitrogen poll
Discussion in 'The Garage' started by Supreme70, Dec 15, 2005.
which would you rather run for airing tire's and arb????
Poll closed Dec 18, 2005.
  1. air compressor with back up tank
    19 vote(s)
    57.6%
  2. air tank
    0 vote(s)
    0.0%
  3. co2 tank
    8 vote(s)
    24.2%
  4. nitrogen
    6 vote(s)
    18.2%
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    Was wondering what people use for filling tire's and running arb's
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I voteed CO2 as that is what i have. Granted it does run out, but it is not like i am trying too run a pit crew off of it
  3. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    CO2 I love it!
  4. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    What size co2 tank do you run and how long does it last???? I'm looking to run my ARB and fill tires from trail pressure to street pressure.
  5. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Still sitting in the garage and need to install but,I voted air.....
  6. readymix
    May 30, 2004
    6,706
    26
    Mine is a 20Lb and it lasts quite a while.
    I just ran it out yesterday and i will try to estimate how much use i got out of it.
    1. Used in the garage for Impact gun and cutoff whel for about 15 minutes of trigger time
    2. Used at the Badlands for cutting a stubshaft out of a truck. The ears were so deformes that it would not come out of the knucles. That was about 20-25 minutes of trigger time.
    3. Aired up 33' on a jeep, 36's on a ford, and 35's on a chevy at the Badlands for two days. Usually just one time per day each. Pressures were from 20 back up to 35ish.
    4. Aired one of my BFG's up at least 2 times a week for 2 months. (slow leak)
    5. Various other, but limited duties around the garage. Mainly whne i did not feel like turning on the compressor
    I also always run it at 125Psi out.
    My crap cutter takes at elast 7CFM to operate
  7. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    CO2, 14.5 aluminum tank for 10 lbs. ~25 lbsT and the PepBoys 12V compressor for good luck. Filling w CO2 is trick when you get back to the tar.:D I mounted the tank on the RR wheel house.
  8. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    This is what I use, I built it my self for about $120, and I can run the impact gun right off it with no holding tank:D:D:D
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    A pair of those 25.00 compressors and a 6 gallon tank under the frame with an 80 psi cutoff switch.
  10. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Can you post pics cause that sounds trick?:bow:
  11. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    have have any pics of the mounting of the air tank and compressers???
  12. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Yeah I haven't really paid attention to how long it lasts but you can get a lot of work out of it.
    I like that it is mobile, I use it in two trucks and the shop, the only real downside is that it isn't 'renewable' like a compressor.
  13. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I have a 300 cubic foot tank of nitrogen:D
    i think is ways more then I do:haha:
  14. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    do u guys have pics of the tank mounts. and the air compressor mounts.
  15. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    No pics but I used a fire extinguisher bottle and so a bracket for one. Bolted to the inner side panel.
  16. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    On board air is nice but after using Toby's CO2 portable tank, that thing kicks ass!:bow: Besides trail use, we used in a salvage yard couple times including when I pulled my new 4L80 tranny. It was a huge life saver getting the torque converter bolts off. Having the portability to take it anywhere is a huge benefit.
  17. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  18. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    What about the co/2 coming out @ 100 degrees below zero? :eek1:
    Any issues with that?
  19. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Geargrinder, is that winch motor or starter???
  20. readymix
    May 30, 2004
    6,706
    26
    We quickly found out that you should wear gloves when using the cut off tool. It will freeze to you hand pretty fast.
    Kinda like in The Christmas Story movie.......I Double Dog Dare You:haha::haha:
