air compressor question
Discussion in 'The Tool Shed' started by 1983Blazerkid, Jan 15, 2007.
  1. 1983Blazerkid
    1983Blazerkid Registered Member
    Nov 12, 2005
    98
    brownsburg, in
    ive got an air compressor and im getting quite abit of oil through the lines got a water/oil seperater on the line but seems like there is still quite abit through it. any input would help. i was going to buy like a new ring kit for it and see if it works just wanted to see what you guys thought first thanks cody
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    cody, is it fairly new? our compressors do that if you dont retorque the head after the first 15 hours then 50 hours...
  3. 1983Blazerkid
    Nov 12, 2005
    98
    brownsburg, in
    its prolly 5 yrs old so what do you reccomend
  4. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    where does your air line come out of the tank? Top, bottom, side?
  5. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    that will affect it, does your seperator have a drain valve? if so, have you drained it or the tank lately?
  6. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    when I got my 80 gallon compressor I filled it up to 120psi then released the valve on the bottom of the tank and I got a TON of gunk to come out...so I was just thinking that if your line is towards the bottom of the tank and you haven't drained it in a while it could cause that.
