Air compressor tubing
Discussion in 'The Garage' started by **DONOTDELETE**, Dec 9, 2002.
    I just bought a Porter Cable air compressor rated at 135 PSI. I need to add a 6 inch nipple to it so I can hook up an air filter. Will a brass fitting be able to hold that amount of pressure or should I use one made out of steel? ... the guy at the hardware store seemed unsure and I don't need it bursting on me. /forums/images/graemlins/1zhelp.gif
  1. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    135 psi, 1/2" pvc would handle that. so you have nothing to worry about with brass
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Brass or steel will be fine. Do not use PVC for compressed air....
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Use a 6 inch galvanized pipe nipple like you'd see in the plumbing section.
    PVC - not the best option.
  4. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I agree, use galvanized tubing. The brass is fine but TOO expensive.
  5. Thanks for the reassurance guys /forums/images/graemlins/thumb.gif I got the brass nipple since the galvanized looks dirty/rough on the inside and might let excess garbage get into my air filter.
