Air Compressor
Discussion in 'The Garage' started by 1979jimmy350, Aug 4, 2005.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    The air compressor that I have says it will produce 8.9 CFM at 40 PSI. The new spray gun that i bought has a 30 PSI inlet pressure and consumes 13 CFM do you think that the compressor is big enough to properly work the gun?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You'll probably need to plan to stop from time to time and let the compressor catch up. Hi volume, low pressure spray guns use up a LOT of air. The larger your storage tank, the less frequently you'll need to stop.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Agreed.
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    if i crank up the air compresors pressure and use a regulator at the gun would this help the compressor work less?
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Nope. The size of the storage tank is the limiting factor (well, other than a compressor pump that isn't big enough for the job). When the tank pressure drops below the 30 PSI that your gun wants, you'll have to stop and wait for the compressor to catch up.
