air compressor
Discussion in 'The Garage' started by 69K5, Oct 29, 2002.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    I think i saw someone on here say you could make an on board air compressor out of an old ac compressor. does anybody know how i could do this? i did a search but it came up screwy. /forums/images/graemlins/confused.gif
    thanks
    69K5 /forums/images/graemlins/k5.gif
    nathan /forums/images/graemlins/usaflag.gif
  2. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
  3. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    here's mine
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    it should basically be the same way with a chevrolet compressor. I am gonna my spare that came off of a 75 K5 blazer. Can i leave it hooked up beltwise as long as i have switch for the clutch. im just trying to save gas and horses.
    thanks
    nathan /forums/images/graemlins/rotfl.gif
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Only thing that is wrong with using a regular Chevy compressor is that it does not have an oil reservoir, so you have to lube it or it will seize. You might be able to run an oiler on the intake, and a oil coelescing filter on the air outlet, but I'm not even sure if this will keep enough oil in it to keep it going. </font color>
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    im nbot sure what those parts were , but i understand the concept. i will look around and see if i can find a york before i start this project.
    thanks
    nathan
  7. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    im right in the middle of the very same install. i got my york pump from the junkyard for $35. so far the only triky part has been geting the home made braket to hold the pulley in the right place and at the right angle. but im pretty sure it will be worth it. if you go to the junkyard take somthing to scrape scum off the pumps. my finger nail was really sore after i used it to clean greese off of the serial # plates. good luck!!
  8. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    ducttape
    i am gonna use my stock compressor from the ac. i like it because its smaller.I did some looking and searches. i
    found some on jeeps and broncos. they used theirs and explained pretty much how to do it. i will keep everyonegood luck with yours
    nathan updated.
  9. Grim-Reaper
    7,385
    Atlanta
    So when are you going to figure out how to hang a york on mine and still retain the factory pump for my A/C ? /forums/images/graemlins/grin.gif I have become a candy a$$ in my old age. My systems still has freon in it and I just sorted out the electrical problem. $30 bucks for a Clutch and a can of freon to top it off and I'm ready to go. Ohhh yeah I want to run twin alternators too. Wouldn't want to get soft on ya and make it easy. /forums/images/graemlins/rotfl.gif
  10. beater74
    May 29, 2001
    1,749
    atlanta
    A/C
    what is this A/C you speak of /forums/images/graemlins/grin.gif
    oh wait i know what yer talkin about it's the knob on the dash of my NEW TOW RIG that make it blow cold air.
  11. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    Grim, sounds like you need to get a little pony motor for the back to start running some of your accessories. /forums/images/graemlins/smirk.gif
  12. ducttape114
    Aug 1, 2002
    990
    Orcutt Ca
    oh. thats cool. let me know how it works.
    ducttape
  13. Grim-Reaper
    7,385
    Atlanta
    I'm thinking of running the york off the PTO. That way I can mount it under the bed and out of the way.
  14. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    grim reaper,
    I am gonna use the factory ac that came with the motor. no new brackets. I looked on the web and came across this website.
    http://www.off-road.com/jeep/tonyc/jeep1/OBAIR3.html
    yall check this out. i am gonna rig up or find a oil seperator that will drain stright back over into the oiler place. the only part that i do not understand is the manifolds. what are those? also shouldnt the popoff valve be in the tank itself? when i get mine done i'll figur out how you can add one to yours.
    69K5
    nathan
  15. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    The manifolds just make one 'outlet' into many 'outlets' (or 'inlets' also in this case) /forums/images/graemlins/thumb.gif
    Jon /forums/images/graemlins/burb.gif
  16. Grim-Reaper
    7,385
    Atlanta
    They don't last. Depdog has gone through several and is converting over to a york. Becides my AC is fixable /forums/images/graemlins/smile.gif
  17. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    thanks
  18. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    the pto idea mighht work. i t would take wsome famcy rigging. i think i might have a york. i redid a vw bug along time ago and the compressor off of it looked a lot like the yorks. i just have to remember what i did with it to see.
    nathan
  19. beater74
    May 29, 2001
    1,749
    atlanta
    i don't know about where you are but here in atlanta yorks a $17 at our local pull-a-part, sh!t they parcticaly grow on trees. any of your local yards should have a late 70-early 80's volvo in there yard.
  20. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    These are some of the links I have found when looking for info on OBA (On Board Air). I have most of the components to put my system together...now I just have to make a mount for it.
    I have so far:
    2 York #210's (one from a volvo and one from a 73 chevy complete with mount )
    Air pressure switch
    5 into 1 manifold from the last link below
    Air tank from a semi
    and a bunch of fittings and other stuff.
    It does not matter where you put the pop off valve but most people put them on the tank. Make sure you have a drain for the tank to let the moisture out.
    http://www.geocities.com/spencerhut/truck/air.htm
    http://www.jeeptech.com/body/york/
    http://www.onboardair.com/
    http://www.rockcrawler.com/techreports/york_tj/part1/index.htm
    http://www.sunperformance.com
    http://www.northerntool.com/webapp/wcs/stores/servlet/NTESearch?storeId=6970&amp;catalogId=4006970&amp;langId=-1&amp;PHOTOS=on&amp;KEYWORDS=manifold
