AIR COMPRESSORS
Discussion in 'The Garage' started by CHEVY 4WD, Nov 14, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I was looking at the Campbell Hausfeld air compressors because they seem to be pretty decent in price and I think they are pretty good(not sure) but then i started looking at the MAX PSI and it said 125-135 dosent that seem low i was thinking it should be around 160-180 am I wrong? Also whats a good compressor for the price?
  2. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Yes.....they are a good brand!
    Most HOME compressors only provide a high of 135 lbs of air because of AMP draw....
    When selecting a compressor.....first find out how much power you have to work with......it is very important.....you can BURN-UP a MOTOR!!!!
    I only have a 30 amp circuit in my garage.....I've been looking at compressors myself!! MAN I WISH I HAD A 60 AMP BREAKER!!!! /forums/images/graemlins/rolleyes.gif
  3. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Well the one im look at is only 125psi is that gonna be enough? Now im used to the ones at the 4x4 shop
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The real magic number to be looking at is the SCFM's The larger the number @ 90 PSI or so the better. As said before, you need to make sure you have a large enough service panel to accomodate the compressor's requirements of amperage.
  5. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    well whats the magic # @ 90 psi?
    atlest what a good number? 10 alright?
  6. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    or even 5.5???
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Anything above 12 is good, 14 is even better.
  8. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    125-135 PSI is fine. Uually only 2 stage compressors reach up past 160 PSI. I prefer an oil type compressor with cast iron cylinders. It'll have a larger duty cycle than an oil less design. There's nothing wrong with an oil less compressor, its just that they don't last as long. You should get at least a 25 gallon tank or preferably a 60 gallon. It really boils down to what you're using the compressor for, the frequency of use, and how much you're willing to spend. I have a small Husky air compressor from Home Depot and it works fine for me. Its a twin-cylinder single stage oil design with a 26 gallon tank and 5 HP motor. Its rated at 5.8 SCFM @ 90 psi and it runs all of my air tools OK (1/2" impact wrench, 3/8" air ratchet, 1/4" die-grinder, and high speed air body saw), plus it has a 100% duty-cycle, which means its rated for continuous use. /forums/images/graemlins/thumb.gif It draws 30 amps @ 110 volts, but I wired it up to 220 volts so it uses half the current (15 amps).
    I do wish it had a larger tank sometimes, but the price was right 'cause it was on closeout at the Depot for $260. It just depends on your needs as to what you should get. My air compressor is pretty much a clone of a Campbell-Hausfield model I've seen at a lot of other places. By the way, 12-14 SCFM @ 90 PSI is a super great rating, but its usually found on really large shop compressors, which = mega $$$$. I'd really like to have a large 2 stage compressor with about an 80 gallon tank, but its way more than I can afford. Hope this helps.
    Will
  9. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    You wish you had a 60 amp? Put one in. I just bought a new compressor, welder, and tube bender. I have to do a little wiring to make it all work but it's not that hard. I am going to pull my 30 amp dryer braker out and put a 60 amp in it's place. Run the 60 amp into a small panel box with 3 30 amp brakers. 1 for the welder, one for the compressor, and 1 for the dryer. The only thing to remember is not to run all three at once.
  10. Grim-Reaper
    7,385
    Atlanta
    I bought my IR 30gallon used for $70. It's rated 9.6 at 90PSI.
  11. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    Has anyone heard of Lotus brand compressors? I just picked up one for $65. The only problem is I know nothing about the compressor itself. It is a belt driven oil lubricated 23 gallon model. Looks like it could be 5+ years old.
    The guy needed money quick, and by the looks of him I might know why! /forums/images/graemlins/eek.gif
    Chris
