Air Con. Blower Fan
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86blazerk5, Mar 17, 2002.
  1. 86blazerk5
    86blazerk5 1/2 ton status
    Aug 9, 2000
    387
    Hagarstown, Maryland
    Hey Guys, i've been having problems with my fan not coming on lately. I think the problem is just in the wire that goes to the blower motor. it use not not come on sometimes so I would open the hood and jigle the wire and it would come on, i would have to do this every once and a while. Recently however, it hasnt come on at all not even when i jigle the wire. I still think its the wire however, has nyone else ever had a similar problem, and how did you, or how could I fix it...? thanks,
    ike
  2. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    Time for a new fan. When it does not come on, try tapping the fan motor housing (inside the engine bay) with a hammer very gently. If the fan comes on then it is likely the brushes inside the motor itself. Just go to Napa or similar shop and get a new one - about $30.00. They go bad sometimes...very easy fix.
  3. 86blazerk5
    Aug 9, 2000
    387
    I will try that. I am kinda thinking it is the bad wire conection, but you are probably right becuase when i jigle the wire it still does not come on. so i will go out and try that. thanks,
    ike
  4. 86blazerk5
    Aug 9, 2000
    387
    Sure enough, a few taps with a hammer and it came right on. Thansk for the geat advice, Assuming napa has them in stock, i will go ahead a replace it some time this week.
    Thanks again,
    Ike
  5. motorheadnelson
    motorheadnelson Registered Member
    Aug 12, 2001
    80
    Fort Mohave AZ
    10 bucks at the junkyard....
