Air condition removal question
Discussion in 'The Garage' started by Tshane, Sep 12, 2003.
  1. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    I have an 86 chevy with air condition. Well it doesnt work and i dont want to fix it. So i want to remove the part that comes out of the cab into the engine compartment. At first i was thinkin i could just take it off and put a piece of steel or aluminum over it. But then i started to wonder if the heater core or anything else that was needed is inside of that. Just wonder if anyone knows if it will be a problem to remove the part that comes from the cab into the engine bay??? Thanks
    /forums/images/graemlins/truck.gif
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes the heater core is in there but if you want it out you can by-pass the heater core with no problems /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. Tshane
    Nov 26, 2002
    144
    Peoria, Illinois
    But if i do that i wont have heat correct. Is it possible for me to move the heater core?
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    no you would have no heat then /forums/images/graemlins/shocked.gif I'm sure you could move it but it would take a lot of modifications to do so and in my opinion wouldn't be worth it /forums/images/graemlins/thumb.gif
  5. Tshane
    Nov 26, 2002
    144
    Peoria, Illinois
    When its 20 degrees out or colder i think it would be very WORTH it. lol /forums/images/graemlins/truck.gif
  6. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    All you need to do is go to the Junkyard and find a truck without factory air and get the blower box controls and wires. Then all you need to do is make a plate where the Evap core was. Also you have to make two holes in the plate for the heater core tubes. This way you will have heat. DO a search on this and someone here shows pics of the plate and other stuff.
    T.J.
    www.tjsperformance.com
  7. triger
    triger 1/2 ton status
    Jan 16, 2003
    177
    Budd Lake, New Jersey
    <font color="green">I just did the same thing with my 90...What I did was remove the ac core disconnected the lines...As for the the heater core, what I did was took the fan housing and cut it in half where the ac core was, then I made a fabricated box from aluminum which is only about five inches deep and connected it to the fan housing and siliconed and and bolted it up...It leaves alot more room under the hood and still able to use the heater core and fan together...Now I am in the process of bolting up the york compressor in the spot of the ac compressor... /forums/images/graemlins/thumb.gif
    T </font>
