Air conditioning bracket question !!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rocko, May 7, 2001.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Okay.. summer is here. I need to hook up my air conditioning again. I disconnected it when I added headers.
    My question is: can I run the AC Compressor without the bracket that connects to the left side manifold (or lack there of) since I added headers?
    Or should I cut the bracket to fit around the header tube and secure it to the head?
    Need suggestions please.. [​IMG]
    Thanks everyone.
    Experience is something you don't get until just after you need it. <A target="_blank" HREF=http://www.rocko.coloradok5.com>http://www.rocko.coloradok5.com</A>
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Definitely secure it in any way possible! Chevy brackets are adequate at best when ALL mount points are
    used so use em all (and then some if you can). Think of the damage that can happen if you toss a belt -
    all other belts go etc....
  3. rustypig
    rustypig Registered Member
    May 7, 2001
    12
    Suisun CA
    I did the same thing. Pep Boys sells an aftermarket bracket (made by flowmaster) that bolts in directly above the temp sender. I had to "modify" it a bit for a perfect fit, plus I made another spacer that went from the front bolt hole in the head to the triangular bracket that sits just behind and between the power steering and ac. Helps to have your own welders/grinders thought. You can do it with some imagination and a bucket of lock washers..bahahahaha
  4. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks guys... Rustypig.. The triangular bracket is the one I'm referring to.. I'll get to work on it... looks as though I'll have to grind off a nice curve to match the header tube.
    I'm not going this summer w/o A/C.
  5. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I don't blame you. It gets hot here in Texas! I have a leaky evaporator. I don't know much about a/c, but someone told me that I have to replace the whole system cause I'll need to go ahead and convert it to the new (treehugger) style.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  6. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Muddin4fun.. You shouldn't have to convert it.. there are plenty of places that still use the good ol' R-12.
    I don't think the R-134a is nearly as cold as the R-12..
