Air Conditioning Prob
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DeesleK5, Apr 12, 2001.
  1. DeesleK5
    DeesleK5 Registered Member
    May 9, 2000
    41
    Dallas, Tx
    Seeing that it is coming up on summer and those of us that live in Hot climates, ie - dallas might need some help with the AC. I got my truck back from the shop a few weeks ago, was in getting frame work, and when i got it back the AC was only blowing luke cold air, basically blowing air, not cold. As i drove though the air coming out of the vents seemed to get warmer, not good, so i turned it off and rolled the windows down. So i figure the fan is working but something else is wrong, any suggestions would be gladly taken
    Will
  2. flcpl4fn
    flcpl4fn 1/2 ton status
    Jan 9, 2001
    194
    Florida
    Mine basicly did the same thing. One day was working great, then the next morning nothing. It turned out to be the compressor and the condenser blew a seal. I was lucky, my brother in law is a GM mechanic and owns his own shop, and he replaced everything and upgraded the freon to the new stuff for under $800.
    '85 Jimmy in Jax, Fl
  3. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    Mine did the same thing at the end of last summer. Im fixing it now. It turned out to be that a hose sprung a leak, let out all my freon, and so the compressor wouldn't come on (it has a saftey sensor in the system). See if your compressor is comming on or not and check back.
    Insurred by Smith & Wesson
  4. BlazerCol
    BlazerCol Registered Member
    Jun 18, 2000
    9
    Roll your windows down and stick your elbow out the window as far as you can, its free.
    BlazerCol
    88 K5
    Ford Sucks
  5. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Funny, I just got the AC working today. Did a upgrade to R134A. Total cost was right at $500 and we are expecting 30's next week. A leak in the system, old hoses, a noncondensable in the system, worn out compressor, you name it can cause your symptoms. Best bet is to either get a set of gauges and do a low side and high side pressure check or take it to a shop and have them run a check on the system. Check the fan belt and see if it's worn. Check all the connections and see if there is any signs of a leak (some oily residue at the connections). Other than that, not much you can repair on the system today with all the EPA regulations in place. The cost to retrofit a system here in OKC is around $350 and that is just a simple purge, flush, change o-rings, vacuum down and refill with 134. This is a short term fix as the entire system will fail generally in about the first year (depending on the age of the components). Sad part is I have the EPA certification and still took it to someone else to service the freon. ($150).
  6. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Low on freon take somewere to have leak checked. Would guess that a hose is bad.
  7. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    what dose r-12 and r134a cost anyways? (I have an uncle who is certified and want to know what he can buy it for)
  8. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    134 is cheap r12 is exspensive. Should find leak first.
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    r-134a is about $3-5 and r-12 is around $70-80 per pound, I think you need somewhere around 5 pounds to fill the system
    Murphy's Laws on Life :
    "It is a mistake to allow any mechanical object to realize you are in a hurry."
  10. Wheels
    Aug 18, 2000
    638
    In OKC, r-134 is $16 per pound and r-12 is $45 per pound.
  11. DeesleK5
    May 9, 2000
    41
    Dallas, Tx
    I will try to check it this weekend, first i will look for a leek and then go from there and check the freon level, we will see, i will let you guys know
    Will
