Air Conditioning question?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Moose, May 24, 2001.
  1. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    Can anyone tell me whats going on with my air. When I run it on Norm there is no difference in that or Max. I don't think somethings switching to make it blow harder. Any help would be great. thanks
  2. mlb79
    mlb79 Registered Member
    May 24, 2001
    40
    evansville, IN
    Make sure your vacuum ball is connected. Sounds like one of the diverters is not working. I would check out the vacuum lines as a first step. I have completely gone through my 79,so hollar if this doesn't help and I will check mine to see if I can help you figure it out.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Correct me if I'm wrong, but I believe that the Norm and Max settings simply refer to the number of vents the cool air comes out of. The only way to increase or decrease the velocity of the airflow is with the fan setting.
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  4. mlb79
    May 24, 2001
    40
    evansville, IN
    The max setting on mine adjusts the side damper under the glove box to a position where the air is recirculated from inside the cab. The norm position pulls air from the outside by moving the same damper. This damper is operated by vacuum and is the big vacuum diaphram behind the kick panel on the passager side. Mine is a 79 so other years my work differently.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    They're pretty much always worked exactly as you described. Even my '94 Suburban works like that. The only caveat that I can think of is that in the early 70's, when you switched the setting to "max", it automagically put the blower on hi to keep the evaporator from freezing over.
  6. mlb79
    May 24, 2001
    40
    evansville, IN
    When the fresh air damper is redirected to recirculate the air inside the cab (on the max setting) the static pressure on the suction side of the fan is increased and the RPM of the fan increases to provide the same or slightly increased air flow. Thats why is seems like the fan is in 4th gear on a 3 speed. Hope this helps.
    79 K5, 3" lift, 400 cubes of nasty
  7. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    What is Air Conditioning? I don't get it?
    <A target="_blank" HREF=http://jimjim.coloradok5.com>http://jimjim.coloradok5.com</A>
  8. Moose
    1,062
    Glendale, Arizona
    Guys hey. I pulled the kick panel on the passenger side and it has a vent like my 77. The only different is that is is vacuum controled. Mine stays closed when the air is on. Am I looking in the right place? Thanks.
