Air Conditioning
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Tonka, Apr 12, 2001.
  1. Tonka
    Tonka Registered Member
    Jan 28, 2001
    30
    Fort Worth TX
    Its about time to turn on the A/C in Texas. Problem is is quit working, probably has leaked the refrigerant out. Instead of working on the old system, I'm thinking of updating it. At car shows, I see alot of older vehicles set up with a newer style compressor that is very small. I've talked to a few of them and they say the smaller ones run more efficiently and cool just as well. Have any of you done this? Is this compressor designed for the new type refrigerant? What else is involved besides figuring out how to mount the thing? I want to say the compressor is called Sanderson, Anderson, Sanders or something to that effect but I'm not sure. Thanks in advance for your help.
  2. BIgJon
    BIgJon Registered Member
    Mar 20, 2001
    19
    One of the main distributors for aftermarket A/C is Vintage Air. (vintageair.com) I do not remember the cost, but their system runs on the new coolent. They told me their kit was completely independent from the original AC and most it mounts under the dash. They could not tell me if it was possible to route the lines for the compressor through the original A/C box or not.. The other choice is to remove the box and weld up the firewall.. Which might look pretty cool.. but would be a lot of work.. Has anyone done this yet???? If I am the first to attempt it (later this year) I will be sure to post the results.
  3. blazerman
    blazerman Registered Member
    Apr 12, 2001
    44
    Sacramento, CA
    My brother retrofitted his old A/C to the newer freon, and all it took was the new compressor, new O-rings in the lines, and having the system flushed and then charged with the new freon. It still uses all the other original parts.
  4. BIgJon
    Mar 20, 2001
    19
    In case anyone is interested, the A/C kit from Vintage Air is $1095.00 It is a lot of money, but my system needs a new compressor, condenser, evaporator and lines.. So I would rather go with the new technology versus the thirty year old design...
  5. 72GMCJIMMY
    72GMCJIMMY 1/2 ton status
    Mar 17, 2001
    142
    I got a R-134a Retrofit and charging kit from K Mart for $30.00. No parts to put in, Just charge port adapters. For pre 76 systems you also need the high side adapter (just a fitting). You can get the R-134 any where if you need a charge. You can also get leak detector,that shows the leaks with a colored oil. You may just have a loose hose or fitting. I have changed over two of my other vehicles, my JIMMY is next.
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I've been thinking of doing an R134 system, but haven't decided on it yet over R12. One of the things I have read is that you need to change out all of the O-rings and the compressor oil. I've also read that you must run higher head pressures, so it is advisable to change the receiver/drier.
  7. 72GMCJIMMY
    Mar 17, 2001
    142
    The kit I got had an o-ring conditioner that goes in with the first charge along with the compressor oil and R134a. As far as pressure I haven't had problems. It blows cold and you can get R134 at the parts store, that was my incentive.
