Air conditioning
Discussion in 'The Garage' started by gotchevys?, Aug 21, 2005.
  1. gotchevys?
    gotchevys? Registered Member
    Aug 20, 2005
    36
    Harrisonburg VA
    Does anybody know what it takes to convert the R-12 air conditioning system in my 89 suburban to use 134a refridgerant?
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    might try posting this in one of the tech areas, the gen spesific forum or the gerage, more likely to get a responce.
    and as for the ac i think it would need a new evaporator, but i dont know for sure
  3. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    It’s really easy if you have the right equipment and kinda know what your doing. You’ll have to get rid of the entire R12 refrigerant, then your evaporator, coil, and hoses need to be flushed. You’ll have to replace the accumulator/dryer and the “O”tube. Replace all “O” rings with R134a type, Put the system under vacuum at 29 hg’s for about 30 min to get rid of all moisture that’s in the system. After 30 min under vacuum, let it sit for about 15 min to let all the moisture boil off, but the system under vacuum again for 15 min. (oh ya did I mention that you need a r134a a/c gauge set) Add the required amount a PAG oil, and charge the system with the required amount of r-134a. The charge of r-134a will be 80to 85 % of the original r-12 refrigerant charge. R-134a operated at a much higher pressure than the r-12 did.
    Check out the following two web site for additional help
    http://acsource.net/acforum/index.php
    http://www.autoacforum.com/
    Dan..
  4. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    look here for some general AC info also CLICK
