air down 8" vs. 10"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TOMER, Feb 3, 2003.
  1. TOMER
    TOMER Registered Member
    Sep 20, 2002
    38
    Israel
    air down 8\" vs. 10\"
    Hallo to you all.
    My question is with which combination can I pressure down more air,The tire is 35".12.5".15":
    With 8" wheel
    or with 10" wheel
    or maybe they are the same?
    /forums/images/graemlins/confused.gif /forums/images/graemlins/rolleyes.gif
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Re: air down 8\" vs. 10\"
    With an 8" you can go down to single digit pressures, with a 10" you can pop the beed much faster even at 15PSI.
    I got my 35/12.50/15 on 7" rims.
    No way I am poping a bead here. /forums/images/graemlins/thumb.gif
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    you would be safer with the 8's. But part of airing down is experamenting. Some tires will fold under themself when aired down to far.
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Go with 8" if you plan on airing down all the time. If you plan on spending a lot of time in the sand definitely go with 8". I've been out in the sand with someone in a K5 and they were always peeling tires off the rim with 33" bias ply on 15x8 and 10-11psi in them. A 10" wheel would've been unbearable.
  5. TOMER
    Sep 20, 2002
    38
    Israel
    Thank you guys
    I defiantly go with the 8" wheel !!!
  6. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    waht about a 10 inch rim with a 15.50 tire? will that hold like a 12.50 and a 8 inch rim?
  7. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yes basically try and go smaller than the width of the tread and you should be better off.
    I personnally would go the narrowest wheel I can fit the tire in.
