Air down
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by badfish4tail, Jul 29, 2005.
  1. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
    I know this question might sound silly to some of you old timers but i got to ask....What is the PSI i should have when i air down before hitting the trail.
    I have 35/14.5x15 boggers on 15x10 rock krawler rims...Thanks
  2. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    im in the dirt alot so i run about 18-20. sand and rock crawling i see people run down 8psi. matter of ure driving style and terrain. maybe others have more input but seems like no other opinions have been offered. start playing around while u wheel to see what u like.
    btw, i have 35" 15.5x 10 bf mt's
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    With my 12.50 33 MTs I usually air down to 15-20 lbs for rocks and soft stuff.
    I go down around 12 PSI for snow wheeling. Thats about as low as I would want to go and not worry about poping a bead.
  4. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    13 psi is what I run out here in the rocks.
  5. badfish4tail
    Mar 1, 2005
    1,684
    Long Beach
    thanks for the info...think i will start out about 20 psi
  6. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    With smaller tires you can't go as low as with bigger tires because you still need ground clearance but with some 36s I had I would go down to 5 on the snow 8-10 on the rocks and sand and 15-20 for mud if you are going to go down to the levels where you could possibly pop a bead you may want to figure out a way to reseat it beforehand I use the starting fluid and match trick has always worked for me but it might be best to go get a junk tire and practice
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    bias swampers can go pretty low without losing much ground clearance.the thicker sidewalls can hold up the truck alot better than radials. i run my 33" tsl's around 10psi on the trail and they barely bulge.
    radials usually cant take low pressure like a bias can. my radial A/T's look flat at 18 psi.
    i would start at 15psi and keep going lower till you have problems. 8-10psi would probly be perfect.
  8. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I've run my old worn 36" TSL's as low as 6 psi in the sand. Even then there was not much buldge in the sidewall and I never lost a bead.
    Bias Swampers will easily tolerate single digits.
    Rene
  9. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    i just started running boggers a few months back and they are STIFF. on my rig i run 11 psi front and 8 rear and they still dont bulge unless up against a rock or other obstacle. when running the tsls i couldnt air down as much, but i think u can try wheeling at around 10 psi for sure-play with it and see what ya like the best Later Ryan
  10. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Are you running 15" rims? I've been nervous to air down more than 15psi front and rear since I lost a bead on my old 38's. I currently have 44x18.5 swampers on 16.5x12 wheels. I'm just nervous about losing a bead while I'm sideways on an obstacle, I'd really hate to flop it and hurt anyone in the truck (sheet metal is repairable).
