Air/fuel mixture adjustment tool?
Discussion in 'The Garage' started by Dunc03, Jan 28, 2003.
  1. Dunc03
    Dunc03 1/2 ton status
    May 20, 2001
    157
    Tyler,Texas
    Does anyone know where I can find a tool to adjust the air/fuel mixture on quadrajet off a 86 305 k5. The screws that are in there don't have the conventional heads on them, or even a normal shape. Instead of normal screws that have a slotted or phillips head, they used screws that are nothing but rectangles on the ends. The things just look like slivers of metal about 1/8 to 3/16 of an inch thick. If anybody has any ideas on how to turn these things I'm all ears. I tried needle nose pliers on the one i just tookoff and they screws turn easily, un fortunately I can't use needl nose pliers on the one that is now install because the things won't fit in between the carb and the water jacket. Does GM make a tool specifically for this or am I going to have to rig something up. Thanks for any ideas you have.
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Take a small piece of copper tubing and crimp over the end of a pointed file or similar shaped object. Worked for me
  3. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    I bought mine at NAPA. I am sure other auto parts stores sell them, Like autozone and Schucks
