Air fuel mixture adjustments... how...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben, Oct 27, 2003.
  1. Ben
    Ben Registered Member
    May 3, 2002
    96
    Pick a country in SE ASIA!
    On my carb, Q-jet, the air fuel mixture screws can be adjusted. Some years back, I watched a fellow adjust them using a vacuum guage but I did not pay close attention...
    Where does the vacuum guage hook to? Which port exactly? And then what reading to I start adjusting the screws at? Thanks!
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    You are looking for a full time vacuum source. You are looking for the highest reading possiblewith the one screw, then switch to the other one. Go back and forth until the absolute highest vacuum reading is obtained.
    Hope this helps some....
