Air Intake?
Discussion in '1982-Present GM Diesel' started by Crunk_K5_1984, Feb 12, 2003.
  1. Crunk_K5_1984
    Crunk_K5_1984 Registered Member
    Feb 5, 2003
    87
    Kosciusko, Mississippi
    What would be the best way to run an air intake route? Currently there's just a hole in the filter housting. Where is the stock intake, and is it in a good position for wheeling? Thanks! Cheers!
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Do a search there are plenty of nice setups with pictures that have been around for a couple of months.
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Search is a nice feature. Plus check my pictures in my sig and you shall see one way of doing it.
  4. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    Thats my setup. What I'm now affraid is i have no WATER collector etc. So Driving in the rain I'm worried of water being sucked in. I'm gonna have to redo it.
  5. Crunk_K5_1984
    Feb 5, 2003
    87
    How would you rig a water collector? And where?
  6. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    Can you rig in a trap (like a sink has) and then put a drain at the bottom of it? would that even work. Just a U bend going down and back up at some point? I've been curious about that.
  7. Crunk_K5_1984
    Feb 5, 2003
    87
    I was wondering that also.. But wouldn't the sucking power from the engine just suck the water in regardless??? Wouldn't some sort of filter placed in the tube work better. I don't know exactly how or what kind of filter you could use but.....
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you don't have a Turbo, there isn't that much suction to draw water up from a dip in the tube so don't worry about that.
    /forums/images/graemlins/grin.gif
  9. AzzKicker
    Jul 28, 2002
    265
    Edinburg, Tx
    ya, i'll probably just make a small dip and drill a hole on the bottom.
