Air pressure
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Jun 11, 2000.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Just put on the new 33x12.50 Super Swamper radials. What kind of air pressure should I run? On the streeet...
    '73 K5
    Chevy good...Ford bad
  2. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    I would run 35 - 40 psi.
  3. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Please post a pic of your Blazer with those tires. What lift are you running? I'm trying to make up my mind on which tires to buy when these wear out. Maybe your picture will help me.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    For the street... Load everything into your Blazer that would normally be in it (couple passengers, tank o'gas, tools, whatever), find a nice flat stretch of warm pavement (concrete is best), and use a spraybottle to mist water on the tire tread near the ground. Just dampen it, don't soak it! Roll the truck forward or backward, observe the wet tread mark, and adjust air pressure to get the whole tread on the ground (NOT the side treads!). Drop 2 PSI lower if you drive highways, and that should get you to a GOOD ballpark figure. Have fun!
    [​IMG] Semper Maintenance!
  5. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I run my swampers at 32 on the street and 10 to 15 on the trail.I have the bias ply ones.My buddy runs the radials and runs 35 on the street and airs down for the trails.Not low enough for me though.Brady
