Air problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FL84K5, Sep 10, 2002.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Ive got an 84 Blazer. When the a\c is off, hot air blows out of the heater vents. If I turn the fan speed up with it off, the air coming from the heater blows faster. When the A\c is on, it dosn't blow out of the vents very hard. Makes alot of noise, but thats about it. On high, you can't even feel it sitting back in the drivers seat. When the a\c is on, it only comes out of the vents, like its supposed it, just not very hard.
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    You need to go through your heater/AC controls. The dampers are vacuum controlled and they can also have things fall through the defroster vents that jam them open or closed. It sounds like you have a damper problem. Just find some time and start taking it apart - you may need some new small vacuum lines - they can get hard and brittle.
