air pump and headers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NYC K5, Dec 15, 2000.
  1. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    im getting my truck its last inspection in new york next month, and am putting a set of doug thorly headers afterwards. if i remove the air pump will my engine still run the same? i have an 85k5 with a new crate 350 that replaced the 305, i also have the sm465 4/3speed.
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Since the AIR pump recirculates air from the exhaust back into the motor, it will probably run better without it.</font color=blue>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Bigray71, you're thinking of the EGR valve. That's what feeds a small amount of exhaust gas back into the intake stream under part throttle conditions. It also helps prevent pinging.
    The AIR pump just sends fresh air into the exhaust stream, just as it exits the heads. Headers that are CARB approved will have the ports for the AIR system to hook up to them.
    http://ThunderTruck.ColoradoK5.com
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    it should run the same try unpluging it and see what you think if you like it take it out if not then just plug it back in
    s.smith 77blazer lookin 4 mud
  5. James
    James 1/2 ton status
    Jun 22, 2000
    179
    Castaic, Ca
    I have a 73 that just became smog exempt. Took off all smog eqip. Air pump. Just put Thorley headers on myself. You can order them with the air injectors or without. It is def against CA law to take off any original smog equipment. I did anyways.
  6. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Have my smog pump disabled at this time.....You might be able to tell the difference on a dyno.
