Air Pump Pulley Siezed! HELP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SAVAGE1, Feb 23, 2002.
  1. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I'm in the process of swapping my engine. I pulled the old engine out about 3 weeks ago. Now I'm in the process of transfering all the accesories to the new engine and I noticed the air pump pulley siezed. I can't turn it by hand, won't even budge a bit. Whats the problem? Do I need a new pump?
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers 14Bolt/ Dana44 4.10's
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
  2. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    i'd say yes- they're like 25 at the junkyard.... don't know what the parts house charges for one.... but if it does not turn over by hand it's shot!
    greg
    * keep the greasy side down *
  3. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    It's gone! Go to to picknpull. I bought one from there for 15 bucks. new areEXPENSIVE! For an 85 was like 250.00
    In theory everything works
  4. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Thanks guys, is that a common thing for air pumps? Its wierd cause it was spinning freely with no problems when I first took it out. Then 3 weeks later when its time to re-install it, it don't budge. I don't get it. Oh well, the Pick N Pull is still open.
    Thanks again
    Rod
    Alameda, CA
  5. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    just leave it off .....and get a new short belt to bypass it ...
    <a target="_blank" href=http://www.imagestation.com/album/pictures.html?id=4292257869&show_all=1&start=1>wheeling and carnage pics</a>
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i second that one
    keep it though. this way if you have an inspection you can put it back on.
    Grant
    take me drunk, i am home
    www.geocities.com/seventy4blazer/parts4sale.html
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if you run cats the pump is mandatory otherwise the cats plug
    formerly 77chev
    still a jerk though
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Where did you ever get that idea? My 89 blazer is still factory under the hood as far as smog goes and DOES NOT use an air pump and it has a cat. Someone down the line somewhere fed you some bad info.
    1989 blazer, 383 stroker, 4.56 geared and detroit locked D44 front and 14BFF rear
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    so because your system was designed to work without pump you believe that an older system that was designed to work with one doesnt need it?
    chev just said 'aww what the hay lets bolt a needless pump on there for kicks'?
    formerly 77chev
    still a jerk though
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    The reason for an air pump on older non computer controlled vehicles is to add an extra amount of oxygen to the exhaust stream to help burn unburnt fuel that exits the exhaust system. Since the vehicle isn't computer controlled there are no other devices helping the air fuel ratio like a computer controlled vehicle has. Some of the early computer controlled vehicles still had an air pump though.
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    you dont say
    i thought it was there to make cotton candy
    so removing the 'extra' oxygen means the unburned fuel stays unburned and clogs the cat.
    doesnt take long to plug the exhaust to the point where the motor is unable to exceed 3000rpm
    formerly 77chev
    still a jerk though<P ID="edit"><FONT class="small">Edited by m j on 02/24/02 03:35 PM.</FONT></P>
  12. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I got one for my 83 aat Autozone. It cost me $26
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  13. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    You must not know very much about later computer controlled vehicles. You also must not have read my entire post before you came up with a wise crack remark. Computer controlled vehicles burn much cleaner than non computer controlled vehicles. This site is supposed to be informative, but with someone like you giving false information this will soon not be the case.
    1989 blazer, 383 stroker, D44 / 14FF, 4.56, locked, 35 BFG mud
    Scott
  14. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    you are gonna cost someone a cat converter needlessly
    formerly 77chev
    still a jerk though
