Aircraft switches with covers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BozoWise, Apr 4, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Does anyone know where I can find some of these switches so I can keep people from bumping mine on and off. I know they use them in all aiviation and I remember there was a member that new someone that new someone's buddy (anyways) I need some "red covered missle launchers" Thanks
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Summit has them, but they are expensive as <font color=red>HELL!!</font color=red>
    Part Number SUM-G3902 $15.99 each
  3. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Wow does anyone know where they are cheaper ;-0 I'll end up getting them there if not. Thanks for the quick response.
  4. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Try radio shack. They have a catalog with tons of switches.
  5. 87JIMMY
    87JIMMY Registered Member
    30
    MN
    Wicks Aircraft Supply 1-800-221-9425 www.wicksaircraft.com has just the guard for $10. They also have the switches and lots of other cool electrical stuff
  6. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Tried the radio shack catalog with no luck..
  7. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    <a target="_blank" href=http://www.wagaero.com/>http://www.wagaero.com/</a>
  9. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I use them at work on missile launchers. I have seen them at Radio Shack too.
  10. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    http://www.rebcoperformance.com/catalog/catlist.asp?catid=10
    This is another place that has some pricey ones. I went to our local radio shack and the guy there thought I was a terrorist and didn't know what I was talking about. No luck in their hard copy catalog or their internet catalog. I am just looking for some that aren't 15.00 each since all I need them for is to turn on a few relays. no current draw needed. I might make my own flip over cover panel for a set of switches if i can't find some for under 15.00 each.
  11. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Here's a little trick from fire apparatus where there are exposed toggles on pump panels/aerial ladder controls to keep them from accidental on/off switching - use a piece of aluminum channel around the switches, just small enough to keep anything larger than a fingertip from being able to flip the switch.
