Airing down tires
Discussion in 'The Garage' started by Masher, Oct 2, 2003.
  1. Masher
    Masher 1/2 ton status
    Mar 7, 2002
    123
    SW Michigan
    Is there anything out there that you can screw onto your valve stem and have it depress the valve to automatically air down your tires?? Something like that would be a lot faster than sitting there holding the valve down with a tire gauge on all 4 tires.
  2. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    yes there is a tire deflator comes as key chain. It has 4 little things that screw onto your vavle stems that will let you deflate all 4 at one time....bought mine at 4wheelparts....Jason
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I always just remove the valve cores, I carry a valve core remover at all times, so it makes airing down very fast.
  4. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I use the Staun Tyre Deflators from Austrailia. They work all the way down to 5 psi! Can be bought on Ebay for around $45 for the set.
  5. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    I'm going to give these a try. /forums/images/graemlins/thumb.gif /forums/images/graemlins/pimp1.gif
  6. samiam
    samiam Registered Member
    May 17, 2003
    42
    I use the end off old tire pumps, available at most yard sales, cheep...the only negative is that airing down sometimes goes too far.
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    I am with Bigmack, I just remove the cores for a few seconds and then replace it and check the pressure. THen repeat this until I hit the desired pressure. CHeap and easy!
  8. stu454
    stu454 1/2 ton status
    Sep 17, 2003
    129
    Corte Madera, CA
    Emmettology,
    Great pic of Special Ed! Yeah!!!! Yeah!!!!
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The fastest way I have found is to get a valve core tool and just pull out the core. I have also tried one of the basic screw-on type deflators but it was very slow in airing down. Another guy in our club just uses a clip-on air chuck. Speaking of this I just saw in one of the magazines where they took a clip-on chuck and attached it with a T fitting, the fitting had an air guage on one side. You just clipped it on and when you want to check the pressure just hold your finger over the open end.
  10. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    That sounds pretty trick. I'd like to see a picture or a diagram of that. /forums/images/graemlins/thumb.gif
  11. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    you don't need to replace the valve core to check the tire pressure...I just check the pressure without the core as it deflates, when its about 3 PSI too high I put the core back in and fine tune the pressure.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I just leave my tires at 20 psi all the time. /forums/images/graemlins/smile.gif
  13. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeah I pretty much leave the onroad tires at 28psi or so, and keep my offroad only ones at 15. dont need no stinkin deflators! /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
    j
  14. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Those Klune deflators look pretty sweet but I bet they're not cheap /forums/images/graemlins/frown.gif Has anybody tried to just a petcock or valve to their rim? You could still check the air pressure with a guage while at the same time dump air FAST (maybe?) /forums/images/graemlins/thinking.gif
  15. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I have the Klune-V Deflators.. They are great..
  16. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I'm with everybody else in that I just take out the core. It airs down real quick. I got some metal caps from the parts store that have the core removal tool on the end of it. Cheep, hard to loose, and if you do loose one you still have 3 more.
  17. Masher
    Mar 7, 2002
    123
    SW Michigan
    Thanks for all the responses guys. I just ordered a set of the Stuans. A little expensive but worth it in the time savings. I like that I can screw them on and then do something else while all 4 deflate.
  18. OL14BLAZ
    Aug 14, 2002
    1,815
    TEXAS, USA
    Glad to hear they do. They looked like they would from the literature I received from KluneV. Did you use your existing valve stem whole or drill a new one? I think I might drill a seperate one for the KluneV deflators.
    Eric
