AK-57 Suspension and 208 Slip Yoke question
Discussion in 'The Garage' started by scrappy88, Oct 11, 2003.
  1. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    I plan on installing the 6" AK-57 suspension (Springer) kit on my K5 in the near future. I'm going to have a new driveshaft built after I put the lift in. I have an np208, and was wondering if I am going to have problems with the driveshaft popping out of the t-case since the axle will now have the ability to drop so far down?
    I'd like to ditch the 208 for a 205 with a doubler setup, but that's way out of my price range at the moment. I'd just like to get it set up with what I have right now.
    Thanks! /forums/images/graemlins/cool.gif
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    If your driveshaft hasn't been lengthed your probably gonna be fine. A few guys that have put the springer kit on after lengthing the driveshaft and actually have to shorthen it. As the axle swings down it actually comes forward a bit.
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    what he said.
    LaBarge is running it and he has a 241. i dont know if he has a slip yolk eliminator or not. he may verry well be.
    Grant
  4. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Brian "LaBarge" is running the Springer setup, and does run the SYE on his 241.
    Drop him a line, he can tell you what he did as far as driveshafts are concerned.
    Rob
  5. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    i have a special springer 6" setup and a stock SY 208 and had no problems at all w/a stock driveshaft.
