AK-57
Discussion in 'The Garage' started by Stroked72Blazer, Jan 29, 2004.
  1. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    Where can I find info about the AK-57? Didn;t they used to advertise here?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    look up... ak-57 from azkickin offroad..
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
  4. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    what do you need to know? /forums/images/graemlins/wink.gif
    I had my own question though. not to hi-jack. But since the shims are off-set are they drilled on both sides? I am in need to rotate the shim 180* to fix my drive-line angles. But I didn't want to take it apart and find that it won't work?
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Things to know:
    1) it kicks ass
    2) that's it.
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Things to know:
    1) it kicks ass
    2) that's it.
    And he has spoken /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  7. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Derek, I do not know why the shims do not work unless you changed something else. Remember that the center hole in the shim is for the short bolt to the spring perch and the offset hole is for the sping bolt. If that is turned around it would cause a problem. If it is setup correctly the wheel should be pretty well centered in the wheel well. Noi matter what the problem is if you talk to me about it I will try my best to help. /forums/images/graemlins/thumb.gif
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Things to know:
    1) it kicks ass
    2) that's it.
    I am short and to the point this year.
    If you want proof, look in the sig. /forums/images/graemlins/waytogo.gif
  9. Stroked72Blazer
    Nov 9, 2002
    352
    Little Rock, AR
    I was just wanting to find the link because a friend has a First gen Bronco and was looking to do something simular. But I am curious: could this set up be pinned for highway use so I could tow with it? I wouldnt ever try to tow a blazer but I would like to ba able to tow my race car or a Ski Boat.
  10. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    well, my angle isn't horrendous but it does get a bit a vibration when accelerating at low speeds and decelerating from high speeds. I have a CV. I was just curious cause I was probably going to try and cure it if I ever had a long boring weekend.
  11. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    The Answer to Life is 5.13's
    No it aint,its 5.86 /forums/images/graemlins/grin.gif
    The answer to life was on back order so I steped up
  12. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    How much lift in the rear does the ak-57 net?
  13. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    Got me 6" but I hear you can choose between four and six.
    If you have a drill, a few friends, and a hole saw you can knock it out in 1 day easy.
  14. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I got 6" out of mine by adding more leaves to the Ford pack. /forums/images/graemlins/grin.gif
  15. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    ... and a hole saw ...
    Whadaya do with the hole saw?
