alcohol fuel
Discussion in 'The Garage' started by Nike, Mar 7, 2003.
  1. Nike
    Nike Registered Member
    93
    Jefferson City, Missouri
    Please refresh my memory in the area of alcohol based fuels (pro's and cons). 10% alcohol mix is now selling for the same price as 87 octane regular in Missouri. Is this a good deal? Thanks Nike
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i think you will get worse gas milage because alcohol burns faster. also DO NOT use it in a premix 2 stroke. when they put alsohol in it, they also have to put a little kerosine in with to absorb the moisture. and the oil doesn't mix with kerosine. Trust me i know this /forums/images/graemlins/angryfire.gif
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Alcohol burs slower than gas not faster. but the flame is a little hotter. What it does is slows down the combustion and evens it out. Kind of like adding octaine numbers.
    Thats why they use alchol or methonol in high compression engines. It stops them from pinging when the timing is advanced.
    Adding alcohol to gas usually wont hurt automotive engines. but it can make rubber gas lines brittle and cause them to break. On some older FI systems it will also do the same thing to the seals in the fuel system.
    I'v ran Gasahol in a few of my cars with no problems. I found it improved performance a little over regular grade gasoline.
    If you run Gasahol all the time I would play with the timing to get the best performance/gas milage. If you advance a lot the timing be sure to check the plugs to make sure they are not running too hot.
  4. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Gas mileage sucks with that stuff. Use the non ethanol... Try a tank of each and see which gets you further. Performance increases are tiny if at all.
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what i ment is that you use more alcohol than gas for the same length of time
