ALDL flash decoding....HELP....
Discussion in 'The Garage' started by heavy4x4, Mar 21, 2003.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Okay, a little background; a while back my SES light would light on the freeway for a few seconds then go off. Now, it's going on much more often. I don't notice any weird driving characteristics on the freeway, but once I get off, my truck idles at a "lopey" or unsteady 600rpm. So, I did the paperclip thing in the ALDL and got code 12 (flash--flash,flash) and then I got two more codes after that flashed three times. BUT for the life of me, I can't find in any of my manuals where these flash codes are given. I know what the various codes #'s mean, but I don't know what code numbers correspond to the flashes I'm getting. Here they are:
    (Flash---Flash, Flash, Flash)
    (Flash---Flash, Flash, Flash, Flash, Flash)
    Could someone please tell me what code numbers these are - that'd be much appreciated.
    THANKS.
  2. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    Code 13 is oxygen sensor circuit. SO I would check your wiring for that, it may be grounding out or becoming open intermittantly. It takes 5 minutes at part throttle for this code to set, which makes sence becuaes you said it did it while going down the high way.
    Code 15 is Open coolant sensor circuit, this code takes 5 minutes of the engine running for it to set. Hope this helps out. I would also check the wiring to make sure it is getting the 5v reference volage and make sure the signal wire going to the computer is good. Good luck@!!!
    Ben 87 Jimmy + 89 Blazer
    /forums/images/graemlins/usaflag.gif
  3. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    fyi, code 12 is a user interface code
  4. Itali83
    Feb 12, 2001
    795
    Westbrook Maine
    Yea code 12 stands for "no distributor reference" If you don't get that three times and the first code you get, your computer is F'd.
    Ben 87 jimmy + 89 Blazer
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    A bad coolant temp sensor will cause both codes 13 and 15 to be set.
    The bad CTS(code 15) will cause a rich F/A mixture. This will cause carbon to stick to the O2 sensor making it throw a code 13
  6. heavy4x4
    Aug 28, 2002
    3,270
    Well, thanks a lot everyone. Itali83, where did you find a cross-reference for flashes and code numbers?
    I replaced the temp sender and tried to replace the O2 sensor also. The O2 sensor is STUCK so that'll have to wait or maybe never get changed. /forums/images/graemlins/ignore.gif
    The service engine soon light hasn't gone on since replacing the temp sender - so I think all is good now. Thanks for your help.
  7. Itali83
    Feb 12, 2001
    795
    Westbrook Maine
    I'm going to school at Nashville Auto Diesel college right now, I was in a computer diagnostics class abouta month ago and my school book had a lot of codes in it for me. SO I took them out of that book. As for the O2 sensor being stuck, and the new Temp sensor changing how much your check engine light comes on, I would change it, becuase it very well could be covered with carbon or just old and dead, giving your computer a false reading.
    On my jimmy I had to get a torch and heat up the manifold and then I was able to break the sensor loose. Once you do that, you'll most likely need to get a O2 sensor tap (it's actually a spark plug tap, same threads) and tap the bung because the threads will be all junky and not good. Then once you tap it, put the new sensor in and you'll be a happy camper. But if it's been in there long enoug to completely freeze in, it's time to replace it. Good luck
  8. Shorts
    Oct 16, 2001
    336
    CC & SA, Tx
    a chilton's manual has them all listed too
  9. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
