ALDL problems
Discussion in 'The Garage' started by tunedportk5, Jul 7, 2005.
  1. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    are you using a correct vin to connect?
    if you have an aftermarket chip you should be supplied with a vin number you'll need to enter in your scanner to check for codes... street and performance's website has a vin on there to use with their chips..
    i tried one scanner and couldn't get it to communicate. went to my friends shop and hooked up his scanner, grabbed a vin from some other tpi vehicle and then i could get it to work?
    good luck man
    you gonna be at blazerfest?
  3. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    This is the problem, you can't convert the WinALDL from serial to USB yet. They don't work right. Find a friend at a shop and use his scanner.
    You do have to have a VIN number to make the scanner work for the Professional type readers.
    The USB to serial converters don't work.
    Good Luck
    Rob
  4. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    OK thats what I was thinking, does anyone have a old laptop for cheap with a seriel port and cd drive.
    I'll be going to blazer fest on sat.
