Alignment on a 3/4 ton Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5RON, Aug 27, 2001.
  1. K5RON
    K5RON 1/2 ton status
    Apr 14, 2001
    219
    Just wonderin' what you set the alignment specs; to the Blazer or the donor vehicle the axles came out of?
    TIA
    Ron
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'd go for the Blazer specs, if they're even different than the donor vehicle. The alignment is engineered for the vehicle, not the axles that are installed in it.
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Unless you are changing the spring pads to alter the caster, just dial in 1/4" of toe-in and go.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I was thinking that it was 1/8. 1/4 sounds a little much but Im not alignment guy either!
    What is and what should never be....
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
