Alignment problem?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Biggedraws, Feb 25, 2002.
  1. Biggedraws
    Biggedraws Registered Member
    Apr 13, 2001
    57
    Gilbert, arizona
    Everytime i push my brake my truck shakes from side to side.. the wsteering wheel shakes too its been getting worse... is this an alignment problem?
  2. Biggedraws
    Apr 13, 2001
    57
    Gilbert, arizona
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    do a search on shimming when you brake...but to me it sounds like warped rotors
    1986 K5 Blazer
    Tired Stock 305/700R4/3.08
    F:2.5" Procomp Springs/RS9000
    R:1.5" Procomp Leaf/2" Procomp Block/RS9000
    Working on getting 33's
  4. 1BAD88
    1BAD88 Registered Member
    Feb 23, 2002
    89
    bristol ct
    I had a simular problem not to long ago it was when I took a corner my steering wheel would wobble-shimmy from side to side it was due to an alighnment problem I also noticed that my drivers side tire was starting to wear funny on the outside so I brought it down to a shop and it was off by 4 microns not much. but enough to affect the steering and my truck would also wander over bumps after it was alighned it cured the problem .hope this helps good luck
    1988 k-5 blazer 5.7
  5. Biggedraws
    Apr 13, 2001
    57
    Gilbert, arizona
    thats what i was thinkin but i thought that warped rotors makes ur truck shake back and forth.
  6. 1BAD88
    Feb 23, 2002
    89
    bristol ct
    When it comes to the front end of a straight axle there are so many things that can make the front feel sloopy and shakey .your best bet would be to pull off your rotors and bring them down to napa or any machine shop and get them turned it's only about 10-15$ a rotor if that dont fix it then bring it in for an alignment .a good shop will inspect all the front parts before they align it maybe one of your tires is out of toe it could be somethimg simple ?? good luck
    1988 k-5 blazer 5.7
