Alignment question...
Discussion in 'The Garage' started by 90blzr, Nov 30, 2005.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    SO CAL
    Assuming the front is a D60. The only alignment adjustment is the toe, correct?
    When aligning a blazer with a D60, should the specs be to a K30 or do a K30 and K5 have the same alignment specs anyways?
    Its close now, but a friend works at the alignment place and is gonna get it right, probably wont last long though.
    Caster (assuming degree shims were used under the springs) would be the only thing that changes when lift is added or taken away, correct? Toe stays the same no matter if you have 4" of lift or 20" of lift?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    Murrieta, California
    All 3 can be adjusted.
    Toe is adjusted just like on a K5, adjust the tie rod
    Camber can be adjusted with plates.
    Caster is adjusted buy either using shims or cutting and rotating the inner c's
